2 JL 12w6's with a PPI a1200 ?
  • Thread starter <MinionStax>
  • Start date
  • Replies 1
  • Views 2K
  • 1
<MinionStax>
Guest
I have 2 JL's 12w6 subs and a PPI A1200 art series yes that's right the old beast, anyway I now have them running at 3ohm stereo, is their a
better way to run the subs. Thank's in advance for any reply's
Definately. Since the W6's are dual 6 ohm subs you could wire the coils on each sub in paralel so that each sub would now be 3 ohms with the coils combined. After this, wire both subs together in paralel again. This would yield a 1.5ohm mono load between the two subs.
I would make sure that your amp can handle that low of an ohm load first though, as damage could occur to the amp if it is ran with too low of impedence.
To my knowledge, 1.5 ohms shouldnt be an issue with a PPI amp, however I havent used them in a while so I would double check first.
Good Luck,
-zane
  • Locked
I have aPC250on Ebay right now that works excellent couple days left on it at auction on the cheapies
I am wondering if anyone has heard or have information on the new PPI vertical PC amps. Are they good for a budget sq class D amplifier. Any...
  • Locked
THESE ITEMS WILL BE REMOVED FROM THIS FOR SALE THREAD ON AUG,16.2022 @9PM CT THANKS
Guest
zane
    May 18, 2024
    May 16, 2024
