2 Mechman 250 Elite and Triple bracket
  • 5
SounDrive
Pro Seller
www.soundrive.audio
3,114
Lebanon, TN
2x Mechman 250a elite hairpin large case GM externally regulated
2x Transpo 911 regulator
1x PAC 80 amp relay for regulators
1x JZ triple alt bracket for 1999+ GM V8 trucks and SUVs
Alternators used for a few months. Regulators and relay will be included. Alternators have a black anodized finish and are large case hairpins. Around 200a idle each, 260a at 1800rpm.
Bracket includes all bolts needed, as well as a Gates HD greenback belt, and a regular gates belt that is 1 inch shorter in case you use alternators with smaller pulleys than these. I will include the original small idlers and two larger idlers as well so you can adjust belt length as needed.
450 per 250a w/ regulator included
875 for both alternators w/ 2 regulators and PAC 80 amp relay
300 for bracket with extra set of idlers and extra belt
1100 for everything
Included
Are they round or rectangle 4 pin? Gotta go on a 96 5700 Vortec and need to know if I would need the cable adapter.
They are externally regulated. They would not hook up to the stock pin but will be adjustable from about 14-19v.
If you need an alternator that ties in with the stock plug, we are a dealer for Mechman and US Alternators.
If only alts would work in my ride. I know where to get a dual alt bracket for decent price and having one of them hairs dedicated solely to audio would be the best upgrade I could do audio wise.
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
629
I was going to run those same Jbl's before I went insane about the car. Glad I would've made a good choice.
SounDrive
Pro Seller
www.soundrive.audio
SounDrive
Lebanon, TN
SounDrive
