2 ohm stable, 1000+ watt Amp suggestions?
  • 5
AIpine
Electronics of America.
I'm looking to get a new amp to power my 2 12 Type R's. (1222d).
Like I mentioned, must be 1000w or more and stable at 2 ohms.
Just looking for some suggestions. Nothing too pricey please. Wanting to spend around $150-$350 if possible.
Thanks a lot!
From experience both the Rockford & Kicker amps mentioned are solid. I wished I would have kept my Power Series 1500-1 & 600-4.
The Soundstream TN1.1200D is a good option too. Remote gain function is a little off though (have to turn it about 1/3 to 1/2 way for it to work-so very small movements go a long way), only complaint with this amp.
Is Soundstream honest with their ratings? They're so cheap
They are with the Tarantula Nano amps. I was a bit skeptical, but then read up on them & gave them a shot. They are the real deal & a great bang for the buck. PPI, NVX, Polk, and Hertz have a line of amplifiers that use the same boards. The NVX versions have made more than rated power when tested. I'm very happy with them & still can't believe the performance that you get for the price. I've had them for a few months with no issues.
It also lowers the amps efficiency and raises the current draw.
5
525
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
328
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
AIpine
AIpine
Northville, MI
whitemax
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
