2 way fuse block question
  • 3
THChief
I am currently in the process of hooking up a second amp. I got the knucpnceptz dual amp instalation kit. Its a 0 gauge to block & then 2 4 gauge to both amps. Do I need a second distrobution block for grounds, or can I just run 2 seperate grounds from amp like normal?
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
645
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
515
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
THChief
THChief
Terre Haute, IN
keep_hope_alive
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
