2-way with extra tweeter or 3-way?
redhotsonic
Hello! Just bought a Mazda MX-5 the other day and I am very happy! Although, the speakers inside are rubbish! I love my music and want to have the best music quality. Good bass and clear audio is what I want.
I've been researching for good quality speakers and found these Pioneer ones! But I do not know whether to get the 2-way set or the 3-way set (there is no 4-way set).
Both my car doors have a speaker at the bottom of the door, and a little tweeter at the top of my door. So, would it be better to get a 2-way and the little tweeters? Or just get the 3-way?
2-way with tweeter: www . pioneer.eu/uk/products/25/131/201/TS-A131Ci/index.html
3-way: www . pioneer.eu/uk/products/25/131/201/TS-A1313i/index.html
Also, the 2-way separate tweeter is 20,0 mm, whereas the 3-way is 11,0 mm. Does that mean the 20,0mm will be better (theoretically)?
I'm guessing the 2-way with tweeter is better, but just wanted some advice from people before I buy.
I really appreciate this and thanks for your advice, guys.
Cheers,
RHS
P.S. I am sorry if I have posted this topic in the wrong sub-forum.
You see, my car is quite small as it's only a 2 seater. So I thought just replacing the speakers and the tweeters inside will do. I don't have room for amplifiers or subwoofers, and all that jazz, plus I wouldn't know how to connect it all or know what wires to get (if any extra needed). I'm not all the knowledgable with cars lol
So, the 2-way set with the tweeters is the way to go you lot are saying? Cheers for the advice.
^^^^^ You never said what your budget was??
2-way setup you can go with a 5,6.5, or 8 midbass.
3-way are mostly tweeter-midrange-midbass driver.
if you go with a 2-way you could look into a small footprint amp like JL,Arc,new pheonix gold,there are a lot of chioces in small amp that you can mount under your seat.
in a 2-way you can use slim sub, like JL,RE,Pioneer,etc......
In a 3-way if you can get a 8 inch in your doors or built pods then a 3-way passive setup will work.
You should go to a local shop to look around before setting your mind on either one.
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
302
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
859
Tons of options in that budget, including the cost of installation,
10
825
It'll look like a "Hawaiian professional" did your install then 🤣
17
redhotsonic
redhotsonic
Somerset, UK
dragnix
    May 18, 2024
    May 18, 2024
