2000 Silverado 1500
its pretty easy the door panels are some 8mm bolts and then you jus pull it off after the bolts are removed and the for the dash remove the trim panel that goes around the gauges, stereo, headlight control etc. then you will be able to remove w.e is that your tryin to
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I only have experience with ct sounds. I have the ct80.4 and the ct1500.1 in my sons camaro he is playing them everyday I had the 80.4AB go bad...
The last piece and the system is a wrap, RUX-H02 remote volume/sub knob because we are old and buttons **** IMG_0647 by Jon Polo, on Flickr...
giantthreat
giantthreat
boston
d3rn7
    May 16, 2024
    May 16, 2024
