2001 porsche 911 SQ Audio Build - Mosconi, Ground Zero and Alpine
We removed the OEM amplifier and made a bracket plate from aluminum to house the fuse holder, distribution blocks and relay. All accessories were attached to the aluminum plate by using screw rivets and screws.
Thats it guys, build finally complete. The system sounds awesome. Has great depth and width on the sound stage. Sub blends effortlessly with the front stage. Here are some exterior pictures of the Porsche 911 with candy apple red race wheels and custom black race exhaust system.
Incredible work right there......//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif:veryhapp://content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
appriecate it man! I was so busy thinking about it that I didn't even think I could look it up with a multimeter.
You should use an adapter. You might gain some insight on a Town Car forum as well. https://www.installer.com/cars/by_car.php?carid=3402
If the company made the adapter for your specific model, they would have taken into account the OEM amplifier and put in a sort of line output...
Hi I have a 2006 Porsche 911 with the original PCM head unit/system. The prior owner had a Mobridge ABT2010 unit installed - it uses a Y cable...
customaudioman
customaudioman
everywhere
quakerroatmeal
    May 18, 2024
    May 16, 2024
