2002 tahoe low volume after new headunit
  • 2
MANTI5
4
Southern AZ
Hey, my neighbor is having an issue with his new headunit and the volume of the rear speakers. The wires are all tight and there's sound from the rear but it's really low. It has a factory amp and works just fine when he hooks the factory headunit back up, he has a PAC module someone told him would help but it hasn't. I haven't had much free time to look into for him so I thought I'd pick your brains to see if there's anything obvious.
What's the vehicle?
That factory amp, my Tahoe has one also, and had to do a little research as far as locating it, remove the harness then remove the necessary wires needed to hook to the amp. Could be the issue.
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
I have a 2001 Nissan Sentra GXE and I've never found one. The loc is the next best option
You may need to go to some shows and sound offs/meetings
12
I would add two more of the same subs and look at selling the 2k to go towards the funds of a decent 5-8k mono amplifier and new enclosure
that was a pain... 2.5 days probably removing everything, cleaning entire area and doing it. ive only done trunk cars before this was def a lot...
14
MANTI5
MANTI5
Southern AZ
MANTI5
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
