2008 Hummer h3 sub suggestions
Derian06
I have a 2008 hummer h3 alpha and am trying to get a pretty decent set up going. Right now I have:
Pioneer gm-8601 800w rms powering 2 champ series 12's (blew one the other day) in a ported box
Pioneer gm-8604 400w rms powering 4 pioneer pro 6 3/4" mid bass drivers and 2 3" super tweets
Pioneer 900w max 4 channel powering 4 (2pionner 2 memphis) 6x9's and 2 tweeters
The big 3
A odyssesus 750cca battery, 0 guage wire to the back, and a soundquest 2000w battery
I want to scrap the gm-8601 and the champ series subs, install a 250+amp alt from power bastards, and replace the 2 12's and amp. Only problem is that my budget for the subs and amp is around 400$ so if yall have any suggestions on what would be the best combo I could get that would be great. Heres a pic of my ride.
I thought people that drove Hummers had deep pockets //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif and didn't have to worry about budgets....
I mean when you spend all your money on your car your pockets get empty quick. I think we can all agree on that.
Thats a pretty low budget for a pair of 12s, box, and an amp.
I would almost want to say ditch the alternator idea and just put all money on subs and amp, or even one stronger sub in a really nice box.
Maybe do something like an SSA 15, if you could fit it. @ciaonzo always has some nice subs for grab.
I just can't justify the alternator upgrade unless you are going to go bigger power or have plans for a stronger system down the road.
I have a 08 H3 and was running 2 zvx V2 12's with psi soft parts on a sk3500.1,stock alt,2 runs of zero,1 odessy group 31 under the hood and 1 of those nsb 100ft batteries in the back. I've pulled it all out now and am going to add a 3rd 12 on a scv6000. Adding more batteries in the back and upgrading the alternator.
[quote name='sherrod833']Here's a video I shot before I took it out.
https://www.youtube.com/watch?v=6m7nn1trswg&feature=em-share_video_user[/QUOTE] holy **** man. On a stock alt? I can't believe that.
[quote name='sherrod833']By the way where did you get those headlights?[/QUOTE] I made them actually
[quote name='The_Grimy_One']Thats a pretty low budget for a pair of 12s, box, and an amp.
I just can't justify the alternator upgrade unless you are going to go bigger power or have plans for a stronger system down the road.[/QUOTE]
My volts drop to 10.3 when running 1200w rms so I think I have to upgrade the alt. Especially since i'll be running about 2300w rms now.
I ended up getting some FU Audio 750 12's at 150$ a pop, now I just need a amp that can put out 1500rms @ 1ohm for around 100-200$ any ideas?
And I appreciate the input yall
I also have a amazon pre built ported box, and I would like to make a custom one. Any box designer I can use?
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
And it works great with android phones, you can connect, and what can you say about android radio tape recorders are now leaders in functionality...
ie just used a new adapter because adapters ignition wiring wouldn't keep constant, works fine now and stopped sending sensors off, never had the...
Try Googling "Amp Pin Out" for your specific vehicle. It will show if the wires for the tweeters come straight out of the amp.
Does anyone know how to install the phoenix automotive tesla head unit in a hummer h2 2004? Hey gave no instructions but claim it's plug and play.
Derian06
Derian06
Madison, AL
C1500martin
maylar
    Jun 2, 2024
    Jun 1, 2024
