2008 Impala LAN and aftermarket stereo question. HELP!!!
adrian1185
More Cowbell!!!
Well, i just purchased a 2008 Chevy Impala LT with OnStar about 2 months ago and now im looking to install an aftermarket stereo and amplifier. The thing is, i dont want to buy the expensive *** harness LAN kit that retains all the OnStar settings and chimes. The crap costs 140 bucks on ebay and sonicelectronix but i was hoping there was an alternative to this. Are there any gurus out there that can help me out? Pointers? Suggestions? Is this thing absolutely necessary because i could care less about OnStar and door chimes.
Unplug the radio and see if anything goofy happens.
I've had error messages on the odometer, losing DIC info/controls, etc.
If nothing acts up you're probably OK to just use the cheap harness.
Also.. depending on the stock system, it may have the factory amp which IIRC is turned on with data.. but I'd have to check for sure. If it is, just bypass the amp.
ie just used a new adapter because adapters ignition wiring wouldn't keep constant, works fine now and stopped sending sensors off, never had the...
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
And it works great with android phones, you can connect, and what can you say about android radio tape recorders are now leaders in functionality...
adrian1185
More Cowbell!!!
adrian1185
Montgomery, AL/Fort Walton Beach, FL
ShiningBuick
    May 24, 2024
    May 23, 2024
