2015 Ford F-150 Crew with Sony System, anyone else having SQ issues?
  • 4
blgaudio
Tennessee
I just recently purchased a 2015 F-150 Lariat SuperCrew. It has the 502A Package with the Sony 700 watt system. I was in hopes that the factory system would be decent enough to keep my audiophile self from doing an install. Well it's been 2 weeks and I'm not satisfied. The factory speakers distort, even with the EQ zeroed out and honestly do not have much volume. The factory subwoofer behind the seat isn't audible at all to me, if barely. The only time I can hear any depth from it is if I'm sourcing through the USB. Sirius/Bluetooth is very flat. Anyone else having these issues? I understand its a factory setup but for the price tag I would expect more!
If you upgrade the entire system you will need to get a processor that sums the signals to get a good clean full range signal and if your truck is the v6 ecoboost you will have to defeat the piped in engine sounds. IIRC that can actually be done at the amp itself.
It is the Ecoboost, I was wondering about the augmented exhaust sound. Makes me think, this could relate to the speakers distorting easily?? I test drove a 2014 w/o the fake exhaust sound and honestly can't tell a huge difference.
There's a trend on one of the Ford truck forums that walks you through disabling it at the factory amp, I believe there are two wires that have to be cut....
Just go by color to color. LF, RF, LR, RR are your speaker wires. Positive + and Negative ( black stripes ). White, Gray, Green, Purple in...
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Not less power but less channels. Maybe upgraded all around Bose speakers as well.
9
I may end up buying the new CDT ES-08 Plus and running customspeakerpods.com 8" speaker pod.
23
3K
My issue is I already have the box (without the 10" adapter ring) so I'm kinda stuck on a 12, which isn't the worst thing in the world 😂 I had...
15
blgaudio
blgaudio
Tennessee
C1500martin
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
