2nd battery suggestions?
  • 2
AndyGiff
CarAudio.com Recruit
Hi guys, been searching around for what I should get but answers are always conflicting. Looking for a second battery for a roughly 3500 watt system. I wont be playing it at all when the car is off. I already installed a Mechman 270amp alt and big 3 etc all zero gauge OFC, front battery is a yellow top Optima, all wiring is zero gauge OFC, battery will be in trunk. Normally only really crank it up when I am on back roads or the highway. Suggestions would be appreciated! Thank you all!
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
This works. Using a 550Watt RMS Amp. The sub is 600-1800 RMS. No Battery Draining BS. Still sounds clean and low. But DD Amp goes lower and hits...
22
AndyGiff
AndyGiff
Fredericksburg, Virginia
marc2112
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
