300 Amp Alt for S10
RXZILLA
Resurrection of a legend…
1,791
Texas
Mechman 300 amp alt w/ regulator
used
450.00 shipped
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
265
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
6
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
221
6
416
RXZILLA
RXZILLA
Texas
StevesCarAudio
winkychevelle
    Jun 3, 2024
