350 timing
  • 3
let the vehicle get to operating temperature(very, very, i can't stress this enough important) > watch something like a plug wire that is vibrating > turn distributor to the point where the wire is moving the least(engine running smoothest) > tighten bolt > kill engine > restart immediately > if the engine has a hard time turning over(like the starter is having a hard time moving it) retard the timing a little...if not, it's set > hit the balancer with a timing light so you know the timing for future reference.
hope that helps
For What It's Worth. I think kids these days use TBH. As much as you dislike shopping at Best Buy I'd say it might be your best option as I'm...
13
Excellent for good sound stage and imaging, don't expect it to move your mirrors or anything. Honestly with what you're trying to do just doing...
12
Update, I found this piece . will give a update after install.. https://navtv.com/products/NTV-KIT889/zen-a2b-dsp12a-a2b.html
796
I knocked out and plugged the internal port which gets me to 5.7', put 6 lbs of poly, 10x34" port should be tuned around 30 dont remember. Just...
29
3K
solox
Registered User
solox
prince rupert, B.C.
Polecat
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
