Astros aren't loud fyi
thats kinda funny. my van has 218,000 and my 86 crx has 260,000 and they both start with a flick of the ignition. THATS BECAUSE I USE "OIL''//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gifI know, They right down there with crxs and caravans......only time they get loud is when the motor is knocking //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
That's not going to be easy, but if you can pull it off I would be down to hear it! You best not be just talking, without a plan it is just a dream, what are you changing up?ive only tested my vehicle at 43 hz. thats it... 2 burps with 2 amps. the first was a 155.2, and the second was a 156.3. and the second amp had to only be at 25%, at least thats what the repair shop said when they tested it and said "it works just fine" then retested and found out. i'll be in the 160's this next season. no problem..
tell the truth a 155.2 sealed on the dash and a 156.3 under the dash with a door open. also i would luv to see you do a 160 on the termlab //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gifive only tested my vehicle at 43 hz. thats it... 2 burps with 2 amps. the first was a 155.2, and the second was a 156.3. and the second amp had to only be at 25%, at least thats what the repair shop said when they tested it and said "it works just fine" then retested and found out. i'll be in the 160's this next season. no problem..
i am buying one of the two amps this tuesdayThat's not going to be easy, but if you can pull it off I would be down to hear it! You best not be just talking, without a plan it is just a dream, what are you changing up?
i for once took your advise on buying BIIIIG, so... and with a lifetime warrenty you cant go wrong...tell the truth a 155.2 sealed on the dash and a 156.3 under the dash with a door open. also i would luv to see you do a 160 on the termlab //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
yeah me too //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif he knows that it is the best meter out there I think he was huffing paint fumes//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
http://www.caraudio.com/forum/showthread.php?t=442260
when the termlab is all that there is around. thats what you use. dont mean i still dont i think its innacurate, its just consistant from one to the other. its not my fault people cant opperate a complicated piece of equipment like the AC and have it set up accurately.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
