4th order folks, tell me if I am on track!
Jroo
here are the specs for my 2 old 10's.
Power Rating RMS Cont. 250 Watts
Max Power Rating-Unclipped Amp 350 Watts
Freq Response 25-150 Hz
Nominal Imp 8 Ohms
Voice Coil 2" 4 Layer
FS 25.18 Hz
Qms 8.8040
Qes 0.3579
Qts 0.3439
Vas 67.30 Liters
Cms 0.3994E-03 M/N
Re 6.93Ohms
BL 17.505 Newtons/Amp
Sd 0.034636 Sq. m.
Mms 0.100017 Kg
Hvc 0.980"
Hag 0.375"
Xmax 0.303"
Xlin 0.605"
Ref Eff 0.2885%
Here is what I have box related.
My max H is 13 inches, width is 16 inches, and lenght is 38 inches
Sealed side is .936
Ported side is 2.042
Port is 55 square inches tuned to 55hz.
Trying to play music from 70 down and be musical. Not worried about metering at all. Will be giving the pair a true 800rms from an old Rockford 800 A2. What do you think so far?
I would bring your tuning down some for a daily setup maybe 45-50
I can not comment on the specs though as I'm on my phone and I don't feel like doing math in my head..far to early for that.
I had a feeling the tuing was too high. If I brought the tuning down, I would have no issues playing 70 down? I would like it to play flat if possible.
If you want more control then I would suggest a 6th order which will typically have a more "smooth" response curve. A 4th order by nature will have a decently sized peak.
i was told a few times these woofers would do very well in a 4th order. What are people looking at to say that they are 4th or 6th order. My 4th could have a peak as long as it down lower.
Firstly and importantly, what vehicle is it being placed in, and where? This will have a big effect on cabin gain which youll need to get an idea for to shape the response of the enclosure.
how much would the Fs play on going low. These subs are basically the credence build house no named solobarics. When I called on them, they said think the old round solobaric with a generic label on them. I would agree that compared to newer subs, these dont have the motor that is out there now. So a larger sealed vs smaller ported aids in how low a bandpass will play?
Ok, so I played with a few online calculators and took the average of what they all said. Each gave me something differernt.
Sealed side 1.17
Ported side 0.57
Tuning Frequency 43.87
They are saying this will play roughly 76 Hz to 25 Hz. These are looking more like the recommendations that Flastrongman said by going way larger on the sealed side and smaller on the ported. I also figure I will keep the port around my original 55 square inches. What do you think now?
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
8
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
4
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
7
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
4
Jroo
Jroo
richmond virginia
Jroo
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
