4th Order Sealing
  • 4
Isaac
Iowa
I am about to build a 4th order for an SA 12 and want to have a removable side so i can access the sub. What have you guys used as a sealer? would weather stripping work or something like cured caulk?
Any kind of elastic sealant would work, be it sillicone, foam, etc. I would use T nuts to mount it to the box so you don't wear out the holes over time with screws.
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
Isaac
Isaac
Iowa
Kangaroux
    Jun 1, 2024
    May 31, 2024
