4th order wall alignment
I'm making the sealed section 10-12 cubes and stuffing with polyfill. Can remove polyfill to effectively shrink the sealed side if need be.
Port will be adjustable/removable so it can be easily tweaked
if ya think that's gonna work for you give it a try. if it was me and i was having trouble getting results id best plotting FR etc..
Only thing is, I don't want to have the port behind the driver's seat because it would be obstructing the port
Steve Mick doesn't seem to have that issue lol I've built several loud 4th orders with driver's side port, seat doesn't really make a diff. You just dial in port opening with seat in the vehicle...
8 15's will be a big *** port, personally wouldn't attempt to do a removable one.....
Ok, gotcha
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
8
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
4
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
7
adulbrich
Olive oil un-virginer
adulbrich
Ames, Iowa
adulbrich
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
