4v Kenwood vs 2v pioneer
I'd go with 4v pre-outs personally. The way i see it is that you want to keep the gains as low as possible, and feed the amp with a higher input signal.
The amp should run cooler and draw less current when idle.
Here's an anology... You have a lightbulb controlled with a knob style rotary dimmer that clicks to turn on/off. Just click the dimmer on, don't turn it past the click. This is the gain turned all the way down. Now, as you begin to turn the dimmer and make the bulb brighter you're doing the same thing with the gain on the amp. This is turning the transistors on with dc instead of signal. The problem is that this level of brightness shall we say, is the zero crossing for the sine wave. This effectively reduces the headroom for a signal transients in the amplifier circuitry.
I would definitely go with the Pioneer. More features, more add on options, and 6-preouts. 2v can be bumped up with a line-driver. As...
5
989
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
592
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
827
gasabozemo
gasabozemo
Lisbon
LosIsATool
