8 15" kicker compd help
  • 1
i have 8 kicker compd subs i'm trying to put in a 1992 suburban. i need some help trying to come up with an idea for a box that will fit the 18's. i have 46 qubic feet to work with. 46.5" wide and 31.5" tall and 54.5" deep. all those measurements are taking in cosideration for 3/4 inch MDF.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
936
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
tallyburban77
tallyburban77
tallahassee FL
tallyburban77
Decebal
    Jun 10, 2024
