A little help?
  • 4
Alanf85
I have been out of the car audio scene for a long time and would like to get back into it. I was looking for some advice from everyone. I have an 05 Honda Accord 4 door with everything stock. I am interested in doing a budget build for under $350. I have been trying to read some of the threads that have already been posted and have an idea of what I want.
1 - 12” subwoofer d4
The amp around 400-600 Watts rms
Box would be sub recommended spec for ported.
I listen to mostly rap/hip hop and electronic music.
It would be nice to get a setup that would be “enough” bang for the buck if you will. I am not interested in super high spl and maybe even leaning towards sq setup.
The subs I have looked at and liked are the Fi Alpha 12,
The sundown sa or e series. Some where along those lines.
For an amp I liked the rf prime 500, and I seen people talk about the PPI 1000.
I hope I’m not wasting anyone’s time just trying to get some decent advice.
Thanks in advance
I have been out of the car audio scene for a long time and would like to get back into it. I was looking for some advice from everyone. I have an 05 Honda Accord 4 door with everything stock. I am interested in doing a budget build for under $350. I have been trying to read some of the threads that have already been posted and have an idea of what I want. 1 - 12” subwoofer d4
Thanks in advance
i think you are on the right track! the alpha and prime 500 is a good setup if you can go with something a tad more powerful go for it..
Thanks in advance
yeah man u have good taste.. idk if anyone would call E sq sub in fact i've seen peeps say they are not but some of that is the box.. 1st are u doing ported box?, highly recommend that for all 3 of these subs on low power.. my p1000 does really well and i almost bought the FI (in fact wish like he*l i did right now my sub is messing up) i just run it at 2 ohm.. p1000 would be good on any of those, fi is 2ohm svc so that would be great with ppi just turn gain down a tad, same with E... the sa u may wanta run at 1 ohm on that with gain low just so u have extra power (this is what everyone told me when i looked at sa).. 1 guy here just got box about like mine with sa and i think 500rms and he said basically it's not enough power.. i would go with bigger than a 500 so u don't end up buying bigger amp next yr..
The big reason I didn’t want to go much higher than 500 rms is I do a lot of driving and don’t want to go crazy with the budget as I’m not sure when it will be time for a new car, and didn’t want to go crazy with the big 3 upgrade along with the other stuff for the higher watts.
Basically I would love a nice solid 12” so I can get some decent quality while being able to hit hard (in perspective) on my limited budget.
Thanks for the feed back guys.
I did a budget build for one of my friends with a Sundown E 15 ( used $60 ) and a rockville db14 2000rms amp ( $129 new, cea 1000 watts so probably 750-1000 true rms) and built a box ($50, 4cu ft at 34hz) and used a knukoncepts 4ga kit ($30ish) and its very impressive. This was in a 2008? maybe, Nissan Altima 2.5 and it doesnt im the lights out
The big reason I didn’t want to go much higher than 500 rms is I do a lot of driving and don’t want to go crazy with the budget as I’m not sure when it will be time for a new car, and didn’t want to go crazy with the big 3 upgrade along with the other stuff for the higher watts. Basically I would love a nice solid 12” so I can get some decent quality while being able to hit hard (in perspective) on my limited budget.
yeah my p1k $169 at 2 ohms over 900rms and i have no head lite dimming at all., i do have agm battery (get 1 of those at advance next time u need a batt) yeah biggest way to save $ is make your own box i didn't and it cost me.. if u must go with 500 get the fi it will be most efficient one., see if u can get just little more power get the E but ppi tested at 600 @4ohm 930 @ 2 ohm it's hard to find another 750 amp for less than that.. we have some good used amp come through here.. had a memphis 1200d $120 last month..
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
191
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
562
Alanf85
Alanf85
Albany NY
BOOMINGRANDPA
    May 18, 2024
    May 16, 2024
