Adding my own HU. Can I leave my factory HU hooked up to same speakers?
  • 1
helleau
Here's what I've done already. I replaced the speakers in my 2015 ford fusion with infinitys all around. They are 2ohm (6.5 reference components in front (but still w/factory tweeters) and 6.5 kappa 2 ways in back) but sound fine hooked up to the factory system.
Then I added a rockford fosgate prime 300x4 amp. It matches up well with these 4 speakers that each run at 75 watts RMS @ 2ohms. I cut the speaker wires a few inches from the factory harness and installed 2 of those cheapy passive PAC LOC units, and ran the rca cables to the trunk. Then from the amp, brought the output back up to behind the factory HU and connected to the factory twisted wires going to the speakers.
THAT sounded like ****! I don't know if it's the ohm load or just the lousiness of the signal from the factory HU, but it ain't gonna work!
So I've decided to mount my single DIN alpine BT USB HU in that neat little cubby space under the dash. I KNOW that unit sounds great, and I've already got all the wiring run.
MY QUESTION IS:
Can I connect BOTH the aftermarket HU/amp and the factory HU to the same speakers? Assuming I don't try to use both of them at the same time of course. So, for instance, if I want to listen to satellite radio, I can turn on the factory HU, and then if I want to rock out, I can turn off the factory HU and then turn on the alpine/amp?
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
848
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
5
748
Thanks. That makes sense. It sounds pretty good as is.
952
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
6
helleau
helleau
atlanta ga
helleau
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
