Adding port length ..?
  • 6
Could I simply add another baffle or two to the inside of the port and cut the width of the port down to 2.25 inches?
well #1 u don't want port to be to narrow as tall as it is.... but u could ad 1 .75 board to inside of port make it 3" wide only thing is how much power are u running? port area really isn't big enough as it man unless u really under powering it..
How much power you runnin'?.. the port area/length is dependent on that in conjunction with volume to avoid compression... modeling up an enclosure usually enables you to get it right where it needs to be (area/length).
Did you model it up for your volume/power OP?
A box calculator cant do what you probably need.
Yea these box calculators are not helping because I have a lot of port noise and I'm not hitting lows as well as I'd like to. Because with a supposed tuning of 36 hz I should still be hitting those 30 hz notes
Unless you got parameters... I cannot help and stand behind it. I looked at a 18 Btl neo in 7ft3 net and I liked around 100in2 of port about 33" long to get it to around 30hz. That said, I'm not even sure what yours is gonna model up at for your power... I erred on the high side of port area as it looks like that driver can take quite a bit more power than you got... good luck
Edit....
is this it?
Fi btl d2 18" ufo
FI BTL D2 18"
2500 W. RMS, 1.4 Ohn Coils
DUAL 2
Fs: 33.6
HzRe: 1.4 Ohms
coilQms: 8.28
Qes:.32
Qts: .31
Mms: 344g
Sd: 1210cm
^2Vas: 133.8
Spl: 93.8dB 1W
1mBl: 25.1 N/A
AXmax: 28mm
Rms: 2500W
Sealed box: N/A
cuftPorted box:4.5-8.0cuftSub
OD: 18.500”Cut
Mounting depth: 11.125”
Displacement: 0.18cuft
Looks pretty much the same to me modeling it up... it'll take a bigger amp for sure to get it near rated
Edit....
is this it?
Fi btl d2 18" ufo
FI BTL D2 18"
DUAL 2
Fs: 33.6
HzRe: 1.4 Ohms
coilQms: 8.28
Qes:.32
Qts: .31
Mms: 344g
Sd: 1210cm
^2Vas: 133.8
Spl: 93.8dB 1W
1mBl: 25.1 N/A
AXmax: 28mm
Rms: 2500W
Sealed box: N/A
OD: 18.500”Cut
Yes that is it. I think 3000 watts is a good start for what electrical I have though. Definitely enough to get it moving. I just am at a loss on how to design a box
Put up your available space and I'll see what I can come up with tomorrow... I gotta work tonight (3rd's).
I came up with about 6.75cf tuned to about 33hz.
I would just sell that box and start over and use better wood the next time. That particle board is probably one of the worst kinds of material to use when making a speaker box. Even if the wood was free, particle board is garbage.
Ok noted. I'm trying to figure out how to get it down to 30 hz
947
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
792
Thanks. That makes sense. It sounds pretty good as is.
990
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
Lmobeats
Lmobeats
North Carolina
Lmobeats
    May 31, 2024
    May 24, 2024
