Take door panel off, look at hole where speaker goes in (in the metal door frame), if it's big enough (which it most likely will be), cut a piece of MDF to fit over that so it bolts to the door completely covering up the hole. Then (I'd wait till you get the rsd's first, so you get the cutout template) cut the hole for the rsd's in the mdf, and mount them in that.
I'd honestly say screw rear fill, these get plenty loud, hurts to turn them up all the way lol. And take the money you saved, and throw 3 or so layers of some good deadener on the front doors. Trust me, you'll need it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
It'd be a waste IMO to wire it at 8ohm (the re that is). Since your saving so much on the front, I'd honestly go with an RE SE (the step up from the sr's, which there's some in the classifieds for under $150), you'll like it much better //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. Not sure if your amp would be one ohm stable on the sub channel, if so, get a d2 version of the se. If not (or not sure) get a d4, and wire it down to 2ohm. You'll love it. If it's too much (which it may be, but you'll get used to it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif), you can always adjust the gains accordingly (PLEASE set the gains with a dmm too, there's plenty of guides online on how to do this. Setting gains too high= clipping, meaning blown equipment)
Not sure about the sr's, but the SE will sound great in a sealed or ported box. The music you mainly listen to will determine the type of box you will want. Typically, if you listen to rap and such music, you'll want a ported box tuned to about mid/lower 30's. If you listen to rock, techno, etc, a sealed box would be more appropriate. Don't hesitate to PM me if you want help with box idea's
Like I said, depends what you buddy listens to. I typically don't like bandpasses, as they take up too much room (compared to a sealed, or even a large ported box). Also, his equipment specs would be nice.
And no idea on pricing of that amp... sorry
