aero question
GiganticPrune
so i decided i gotta build a new box before it gets really cold, i plan to do aeros this time and vent through my ski hole.
sub - CD omega 15
plan to do 3.0 cubes @ 32, but what size aero should i do, size and length.
aaaand, would it be an awful idea to just use some pvc instead of paying $30+ for a flared aero?
Flared aeros are better than just PVC with no flares. A 6" aero would work, but for 3 cubes @ 32 hz you would have to make the aero about 21" long, which means you'd have to buy an extension.
okay. so bumping this thread. if i do (4) 4 inch aeros, how long should they be if im tuning to about 32hz?
edit: nevermind. found a calculator. answer is 16 inches if anyone was wondering
I'd just bump the box size up to 3.5ft^3 and use a full length 6"er to get the 32hz tuning...either that or do a slot port.
x2 i would do that. actually i would do that if you want to tune to 32hz myself id tune to like 37hz. should give you more overall output
i couldnt get access to 6 inch unless i wanted to buy a giant length of it, and i couldnt fit that in my car. but i did bump up the box size to 3.5
6" PSP Aeros on partsexpress and madisound //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And yes, I agree with a single 6" or 2 4" if all else fails. Hard to go wrong with PSP flared ports for ease of use.
so built the box. been using it for a few days. its at least 2x louder //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
now unfortunately im havin some huge voltage drops. 180 amp alt. yellow top under the hood (which is about 4 years old and lived a HARD life) and a kinetik 1800 in the trunk. running a sundown 3500. im not sure yet if theres a problem in my setup or i just dont have enough batteries...plus its also been like 19 degrees in chicago for the past few days. im sure that doesnt help
With a 3ft^3 net volume box??? They'd have to be 42" long each for a 32hz tuning. 16" long each and you're right around 50hz for your tuning with four 4" aeros.
With a 3ft^3 net volume box??? They'red have to be 42" long each for a 32hz tuning. 16" long each and you're right around 50hz for your tuning with four 4" aeros.
whaa? no. 3.5^ft3, 2 4 inch aeros. about 16 inches long. i used psp's website to get those lengths. hits pretty **** low, so im pretty sure its not 50hz.
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
298
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
661
GiganticPrune
GiganticPrune
Orland Park, il
E2theloc
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
