my sears plat 31 agm battery has shorted out 2 times. I have my amp on half ohm and I have a 275a singer alt, plus all the a appropriate wiring and it's still shorting. would adding a batt in the trunk help this?
First off you have to understand why it's shorting out before you add more batteries. Do you have fuses in your set up? By adding a battery and haven't fixed the problem, you'll have to remove two negative cables if both are grounded to the body in case cables start to arch and save the car from burning.
