Alternate Grounding Options
  • 4
Premium Member
Current build, 2012 Mazda 3 Hatch 2.5T
2,110
764
Boise, ID
I posted replies to some forum threads last week and some were intersted to find out why or howI do my front to back power/ground configurations. It's seems that a lot of people are not familiar with this optional method, that with todays unibody cars might offer another solution.
I posted information regarding running parallel (not parallel grounds as in this article) but parallel cables (1/0 power and 2/0 ground) from the primary battery to the 2nd battery and instead of grounding to multiple chassis points (in my build’s case, 6), using a distro block to run all your grounds back through the 2/0 ground going back to the battery. Doubling the ground wire gauge or running two 1/0 grounds helps negate the need for a parallel ground as it is mentioned in this article, but this is just another option.
I initially learned (what I was suggesting) years ago when working on early model Corvettes (fiberglass body) and later on my Saturn (Pulse alloy - GTX for the quarter panels - Dow Plastics, polycarbonate and ABS (PC/ABS) and just carried it forward to my present builds. It has worked great for me and has all but eliminated ground loop issues, for me.
Here is another way, kind of a hybrid of what I do and what is the most common method, chassis grounding. This type of ground is called a “Parallel Ground” and it’s recommended by some pretty heavy hitters, notably Arc Audio, JL Audio to name a few. It incorprates both the chasis ground and extra, direct to battery ground.
Here is the article from ARC Audio that explains it pretty succinctly. Can’t have too much information, right?
Enjoy!
Can't be "TOO" grounded, right? I recall, years ago, my dad would find a place on the block, run the goround to that and the power to the battery terminal. He would say the car really got a "kick" out of starting (jumping) it this way!
U talkin bout the wires in the speedo cluster ?..if i ground the wrong wire,me no longer can see speed ? Or the arm on the gauge of the speedo not acting correctly resulting in a blown amp ?
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
I had a really hard time with my 1990 240sx. That had to have been the hardest car to wire up and install to date. The doors were something else
Ohmmeters measure resistance by measuring voltage and comparing the voltage to a known resistance. They cannot accurately measure resistance on an...
Premium Member
Boise, ID
spokey9
    May 12, 2024
Brendon Jenness
    May 11, 2024
