Amp for svc dcon
  • 4
Hookedup12
NC
Sealed dcon 12 svc 4ohm I want to know what would be the best amp to use I don't want to power it over 400 rms its a daily driver. Some ppl recommended 2 Chan amps. And some monoblocks what is the best amp for 300-400rms @4ohms????
How much does it put out
800 rms but set the gain nice or run it at 4 ohms and ull be right at rated
---------- Post added at 11:12 PM ---------- Previous post was at 11:11 PM ----------
That 800 is at 2 but even then just be easy on gain that's how I'd runs it regardless
---------- Post added at 11:12 PM ---------- Previous post was at 11:12 PM ----------
Plus if its clean that ssa will take a Lil juice //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
138
6
369
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
669
Hookedup12
Hookedup12
NC
Hookedup12
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
