amp has power but sub dont play?
  • 4
sq_joshua
I was playing music not even loud then all of a sudden my bass cut off i checked my amp and it still had power and my fuses are not blown but if i play music you could feel the sub playing but doesnt play normal as it should u could just feel it playing even tho i put the gain up and i took my sub out of the box and looks fine. What can it be.?
In addition to checking the coils with a multimeter, check the ground for the amp. It should be bolted snuggly to unpainted metal. Also check the RCA connections to make sure they're good.
Check your remote line or RCA, some decks have written remote 2 times different wires one solid blue one blue and white, some do the misstake...
10
74
324
  • Locked
638
Amp
468
sq_joshua
sq_joshua
los angeles
sq_joshua
    May 31, 2024
    May 24, 2024
