amp help :)
  • Thread starter barba3
  • Start date
  • Replies 3
  • Views 2K
  • 2
B
barba3
Guest
hi!
i have 4 JBL speakers (6X4 inches), an EQ and i plan to buy a woofer.
which amp do u recomend??
i DON't want it to be loud, i only want a good sound and separate high and low frequencies (woofer and speakers)
THANK YOU
You might want to check out a 5 channel amp. Four channels for full range, and a seperate sub channel. There are several different manufacturers that make them. My personal favorites would be the Kicker or the Rockford Fosgate. But that's just my humble opinion //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
barba--- you might want to check out precision power
powerclass ( pcx 5800) it a 5channel amp rated at
50x4 into 4ohm per channel plus 200x1 into 4ohm (sub )
100x4 into 2ohm per channel plus 400x1 into 2ohm (sub)
and 200x2 into 4ohm bridge plus 400 x1 into 4ohm bridge (sub)//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
There is honestly no way to answer your question.....
You are going to buy a woofer and want to know what amp to power it with. Since T/S parameters vary greatly with each model of woofer- actual power needs are contigent upon which woofer you select.
A little more specific info please.
take it easy,
-zane
11
853
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
564
That is correct. I like these as they are twisted pair and the RCA ends are thick and grip quite nicely...
9
961
Guest
zane
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
