amp issue
  • 1
eenyuheye8o8
I got a clif designs 4800.1 and I got it all wired up and hooked up and when I closed the trunk lid it made a loud thump. Then I looked again and nothing was touching and stuff. Then tapped right above the logo and it was thump off the yin yang. I was wondering if I open it up is there should I should look for in regards of my problem. Like something grounding out? I've tapped other locations of the amp and nothing happens only when I tap right above the logo. And also I've played it at low volumes to maybe about 14 on my pioneer 4500 and it sounds good. But when the bass hits hard it starts thumping like someone's having a seizure. And my door speakers start crackling. So I'm thinking it has to deal with something vibrating the amp and making it do that.
I would do the same. Its possible its up under the dash or behind the glove box
14
Pull the amp out, bring it to the front of the vehicle, and connect it to the battery. Does it power up? Go from there.
7
Is the amplifier secure/bolted down or has it been moving around/just laid down in the vehicle not secure? I would check your wiring connections...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
152
eenyuheye8o8
eenyuheye8o8
Mililani, Hawaii
eenyuheye8o8
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
