Amp recommendation 2xSA8 V1.5
  • 4
BLK MAJK
Looking for some amp suggestions for my new setup. I think I have a short list of amps, so I'm just trying to make the best decision. I recently got a pair of Sundown SA-8 V1.5 subs. These are the 400w RMS models. Dual 2 ohm VC. I plan on wiring them to a 2 ohm load. I'm thinking I want/need an amp that does 1000 RMS @ 2. Car is wired with Knuconceptz OFC 4 gauge. Amp is getting signal from a LOC (want to keep my factory nav) wired into factory sub (its unhooked). Car is a 2012 Kia Optima with the factory Infinity stereo. I will be building either a shared box, or 2 boxes (1 in each wheel well "bumpout" in the trunk). Either setup will be ported. Just looking for a daily driver setup. Budget is $200 so I'm looking at used. So far my list has the following.
Alpine MRP-M1000
Hifonix BRZ1200
Boston Acoustics GTA-1000M
MB Quart ONX1.1500D
Kicker DX1000.1
JL AUDIO JX1000/1D
Soundstream Rubicon 1600
Any other suggestions? I know I have seen the Audioque 1200D mentioned as well but I'm not seeing any of those around used. Thanks for any help!
134
366
  • Locked
666
Amp
482
BLK MAJK
BLK MAJK
United States
na_rsx
    Jun 1, 2024
    May 31, 2024
