Amp removed from car I bought. rear speakers weak.
  • 2
That could be a possibility, but both? And sound is not bad so to speak, just extremely weak.
I'll probably try to bypass the amp wiring and go back to direct from hu to see
217
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
419
6
497
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
791
Mrjimmy
Mrjimmy
Colorado Springs
Mrjimmy
