Amp settings help
Subsonic should be 2-3hz below box tuning. LPF around 80 on there or the head unit.
Use this as we've posted before easy to figure out with their calculators for the gain voltage settings and a multimeter using a 40hz test tone. Test tones are all over the place online. Steve Meade's website has them for download very easily.
How do you accurately set subsonic? Isn't the knob labeled in the vaguest of ways, a high and low value?
Do you play a tone at desired frequency and adjust subsonic to right where it effects the sound output?
set your gain right, heres how. test tones are at the very bottom...
You will need a multi-meter, a set of RCAs that will be sacrificed, and a small blade screwdriver. First disconnect the amp from the LC2i. Now cut...
Thanks for the info, made the setting changes and that did the trick. Toyed with the amp gain to get the amplitude balanced out, then tweaked...
The switch goes between the speaker and crossover.
43
4K
GoT_2B_BuMpN
CarAudio.com Recruit
GoT_2B_BuMpN
No Conway, New Hampshire
some dude
