amp sparks
05fronty
SALT PETER
11,937
conway,ar
i pulled out a old mtx blue thunder out of the closet to see if it still works. i hooked it up. powers on but when i tested a spearker to it just touching the terminals it sparked at the speaker. does it mean the outputs are bad? i haven't checked the fuses on it yet though. it has 3 30 amp fuses on it.
was the amp on when you touched it and it sparked? touching speaker terminals while amp is playing is a //content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif
yeah my bad. it blew one of the fuses on the amp. i will try tomorrow with the power off. thanks
85
335
  • Locked
642
Amp
471
05fronty
SALT PETER
05fronty
conway,ar
05fronty
    May 31, 2024
    May 24, 2024
