amp time
The new Kicker ZX amps are really nice. I never really was a fan of Kicker, but for some reason I like them. JBL GTO, Alpine PDX, If you want a good budget amp look at Profile.
Is the L7 you have in the Dual 2 Ohm or Dual 4 Ohm configuration?
The above is still something that needs to be answered...
I would go for an amp the will have a power output the same as the rms of the sub.
Same power output as the RMS rating for the sub at the correct resistance load which will be entirely dependent on the voicecoil configuration of the Solobaric L7 he has...
2 ohm is the voice coil... anybody of audiopipe??
suppose i get a amp with wattage over the rms or max wattage of the speaker...
2ohms on each coil? or 2 ohms when paralleled? you need an amp that will push 800-1000rms (if the l7 is rated for that which i think it is) into 2ohms. more than likely a kicker zx1000.1 would work out for you. theres been some on sale in here too.
hifonics is alright, but if you save up youll be happier in the long run.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
137
6
368
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
666
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
483
blackkila.gtr
blackkila.gtr
Nevada
boomzilla
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
