amp to subs help
since their dual 2 ohms you could wire them to 1 ohm and get a 1 ohm stable amp. (so keep your options open.) But that 1200w rms would go to both subs, meaning each would recieve 600 rms each give or take. But for a 15 just recieving 600 rms sounds kindy fishy, what brand you get?
BTW....Whats the specs on them?
you cannot wire 2 dual 2 ohm subs for a final load of 1 ohm, only .5 or 2 ohms.. and 700x2 is 1400, not 1200
wire them to 2 ohms, find a amp that does about 1400 for those subs
kicker zx1500 would do you good, just set your gains right
uhh two dual 2 ohms would result in 0.5 ohm, 2 ohms, or 8 ohms...correct? unless im missing something?
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
$D-Money$
$D-Money$
Douglasville, GA
MyPoison1
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
