Amp won't read 1ohm
hellastock_rsx
So I wired up two DVC 4ohm Boss Phantom 15s to a Planet Audio AC4000.1D amp (1ohm stable) for a buddy. I wired them as the attached photo shows so that the amp is suppose to read 1ohm but for some reason when I check the independence at the amp terminals it reads 4ohm. He's happy with it but its bothering me why its not reading 1ohm like its suppose to. Could it be a problem with the amp?
Hope you are not using that $5 Harbor Freight meter. It does ok when reading battery voltage but when it some to ohms, the numbers jump all over the place. In my experience that is
yeah could be meter i had one read 19v on my battery 1 day lol.. i have another cig lighter volt meter shows 13.7v but good meter test at amp shows 14.1.. 1st change battery in meter, then test and like he said test each sub..
Sorry for not responding for so long but I forgot I posted this. I'm not sure how nice of a meter it is, I've used it on my subs before and it read the correct independence but I said somthing to him about taking a look at it and he said he's not worried about it so I guess I'll never know
here's a bigher pic of the way i wired them though
6
281
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
577
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
439
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
499
hellastock_rsx
hellastock_rsx
Canton, OH
hellastock_rsx
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
