Amplifer for Dual DC Audio 15'' Dual 2Ohm Setup
Shelbywh89
Hey, Guy
Looking for some help...looking for the perfect amp for two DC Audio Level 4 15''s
Was looking at running two Sundown SAE-1500 at 1Ohm...$800 is my budget
I see some people running Audiopipe APCL-30001D at 2ohm but never have delt with any Audiopipe amps.
Thanks for any Help
Sundown Audio, DC Audio,....
I agree on the Twisted (Sister)Sounds. very under rated amps and seen them do a lot more than rated.
Your amp may have failed. A competent shop should be able to diagnose the issue in under 5 minutes either way. You didn't necessarily do...
6
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
89
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
432
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
940
Shelbywh89
Shelbywh89
Seattle,WA
Boomin_tahoe
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
