This not what you think it may be.
One does not bridge a monoblock subwoofer amplimer, just to set things straight. Bridging is what you do to a multi-channel amp to combine the output of two or more channels to one. You won't be doing that here, with two subs and a monoblock subwoofer amplifier.
With Dual 2 ohm VC woofers, you will need to wire them as follows for a 2 ohm load to the amplifier:
Those Kickers are rated for 750 watts RMS, each or 1500 for the two.
What is the budget, there are plenty of amplifiers out there that work at 2 0hms with decent output. The stinger and Recoil lines offer some decent sub amplifers for the money.
This Stinger puts out 1500 watts at 2 ohmse $200
This Recoil does too $180
3K 3000 watt Taramps $260
Are you set on the Kicker? Lots of 12s out there that I think perform as good or better for less money.
A couple of these 15" NVX for instance $210 each (1200 watts each)
Product Features: 15" Dual 2-Ohm VC-Series v3 Car Subwoofer Power Handling: Peak Power: 3000 watts RMS Power: 1500 watts Impedance: Dual 2 ohms Xmax: 23mm (One-way) Carbon Fiber Enhanced Non-Pressed Paper Cone Custom High Roll foam surround with black nylon stitching Die Cast aluminum vented...
nvx.com
12's $190 each (1200 watts each)
General Features: 12" Dual 2-ohm VC-Series v3 Car Subwoofer Power Handling: Peak Power Range: 2400 watts RMS Power Range: 1200 watts Impedance: Dual 2 ohm Xmax: 23mm (One-way) Carbon Fiber Enhanced Non-Pressed Paper Cone Custom High Roll foam surround with black nylon stitching Die Cast aluminum...
nvx.com
The dual 2 ohm version of these #280 each
These are outstanding subs $269 each
stereointegrity.com
