Alrojoca 10+ year member
- Thread Starter
- #16
Trumpet, I hope you can see this post again. I was busy the last few days doing the work.
I checked the rest of the link and seeing #7 putting MLV on the doors, I did it a bit differently and I wanted to ask you what you thought.
I used no glue or velcro to my doors with CCF and MLV . What I did was I cut the MLV and attach to the door card. The CCF I put it on the inner door side facing the MLV and card. I attached the CCF to the inner door with some clips and caps already on the door and also the bracket and items that are screwed on the door and that holds the ccf, I did not cover the section where the door car clips are on like I did with the MLV but I managed to cover with CCF most of the area the MLV touches, also I read Don mentioning on some other forum that the air between the inner door and outer door even with no CCF will work as a decoupler, I figured just a few inches it is no big deal.
Here are some pics of how I did it. Basically the CCF is on the door, and the MLV on the card before installing it. When the card is removed the MLV comes out with the card, tricky to put the card on but it worked fine.
Is this a good way to do it? or should the MLV should always be velcroed to the inner door?
Thanks
Thanks
