Another box for the Maxima (1 15" Type R, 4cu. ft. 33hz)
  • 4
As for the 1/2" mdf, you just made a few wrong cuts
As far as the port piece goes, just use a straight edge to mark on the top and bottom of the box where the center line of the port piece is, then drill your holes.
but the port is so long that it wabbles, even when the front part is screwed down...
what im trying to say is you have to screw the port piece down on the bottom piece, AND the side piece... I screw the side piece on, THEN that is where I get lost
What you need to do is, attach the port to the baffle first, flip the box over and draw in the port in pencil on the underside, drill and screw in the middle of your drawing, and you'll be good to go. A few degrees off won't hurt anything, so don't worry about that at first. It all comes in time.
well I got the box installed and running today... Surprisingly it got ALMOST as loud as the 2 15's...but I could tell it didn't want any more power... SOOOO that being said, after experimenting around, I am going to sell one of the 2, and hang onto the other one for possibly future use.
This $100 over your budget but it checks every other box https://stereointegrity.com/product/bm-11/
10
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
769
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
snb778
blaugh!!!!
snb778
ex. Los Angeles, CA
snb778
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
