Another Championship Ring
They have been talking about it. but there are a lot of areas that have passed noise ordinances about loud stereo. and there would be a lot of shows in the Ohio area that would get shut down. Even SBN in Florida has had trouble the past few years with the police and noise.
how do you know what volume to go to on the headunit without going over? does it change with temperature? and how do you compensate for the voltage drops and such? db drag has always fascinated me
Basically you need to test and write down everything. temperature humidity voltage. everything. and then dot all again and again and again. and you will figure it out. it just takes a lot of time
Yea there are many different ways to do it. But I know that all of my testing has worked for my and my teammates. we have 11 world titles in bass race over the past 4 years. Not saying it is the only way. But it has worked well for us.
Yea I was planning on going that route. I'm sure it'll sounds close to what I'm expecting
16
189
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
792
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
TeamProdigyMike
TeamProdigyMike
Houston, Pa
TeamProdigyMike
    Jun 1, 2024
    May 31, 2024
