another *FacePalm* Question....
  • 7
Tek18
KY
sorry for such dumb questions im just curios
k so i have a FI SSD 15"... bought it at 2ohms
im sure there are other ways to wire it but + to + will make it 1ohm and + to - will make it up to 4ohm.
what if i bought a 1ohm amp and wired the sub at 1ohm, and played it at 1200 Watts RMS
then i bought a different amp, that could handle 4ohms at 1200 Watts, and i wired it up to 4ohms and played my sub at 4ohms 1200 watts
what will the difference in this be?
If it were a perfect world and those were the only variables... nothing would be different.
In this case you're better off at 1 ohm. That's really all you need to know.
If it were a perfect world and those were the only variables... nothing would be different.In this case you're better off at 1 ohm. That's really all you need to know.
Sounds good, So im guessing the higher ohm load on amps is for speakers when you have so many you can't wire them all back down to 1ohm?
If the ohm load is higher (4 ohm vs 1 ohm) it would be less of a draw on your electrical. Somebody correct me if I'm wrong here?
if the amp were made to put out the same power wired at that impedence, it would theoretically have the same draw. In reality there aren't any class d amplifiers that put out that power at 4 ohms that I'm aware of. So it would actually draw much more than the class d to put out the same power.
through the same amplifier, but if i have 2 different amps and at 4ohms and at 1ohm on 2 different amps they both pull the same amount, i was just curious the difference
my KICKER is rated at 1500 @ 4 //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Correct. I guess what I'm saying is, he will need a stronger electrical system for an amp putting out 1,500w at 1 ohm vs an amp putting out 1,500w at 4 ohm. Right? Or am I way off here?
The supply voltage is the same. It's a constant. Let's assume 12.6v. Assuming both amplifiers have the same efficiency, let's say 85%. They both put out 1500w. So, they would both draw 136.9 amps of current. What about this do you disagree with?
I'm not disagreeing with any of it. I'm just thinking the theory I've known all along is way off lol
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
599
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
Tek18
Tek18
KY
wickedwitt
audiobaun
    May 19, 2024
    May 19, 2024
