Another question about setting gains with a DMM
  • 2
SomeguyinPDX
GunHappy
Yep, another question about setting gains with a DMM. I used to know the formula when I did my monoblock: Sq.Rt. of watts x Ohms (sq. rt. of 1776watts = 42.14 x 1 0hm= 42.14vac) Correct?
Now I'm doing my gains on my a/d/s 8 channel and am not sure how to calculate it since I have all 8 channels bridged down to 4 channels. The amp is rated for 8x60rms@4ohms and 4x180 bridged @4ohms. Their is one gain control for each pair of channels for a total of 4 gains. Basicaly this is more like 4- 2 channel amps under one housing.
Is this correct? Sq. rt. of 180w=13.41 x 4 ohms = 53.66volts A/C
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
Haven't 100% landed on which one, but I am down to those two
Was deferring to the smaller box aspect of the post. 1 Hi-Q 10 will never get as loudasthedual NVX 15's. The Savard are excellent speakers.
101
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
785
SomeguyinPDX
GunHappy
SomeguyinPDX
Portland, Or
SomeguyinPDX
    Jun 1, 2024
    May 31, 2024
