AP mini amps
links?
---------- Post added at 11:53 AM ---------- Previous post was at 11:52 AM ----------
put a mini amp in fathers motorcycle, sounds pretty good not sure of the brand though.
Ive heard the monos do rated. but ive not heard anything about the 2 and 4ch. From my previous experience the ap and aqx series was a bit noisy.
i have the 4050, it's solid it was for my s10 but my zx650.4 crapped out on me and I have to use the 4050 until my kicker amp is fixed. It's a solid amp and pushes my ID ctx65 comps really well, not as much power as the kicker but its good clean power, def. worth the money. It's also TINY like a dvd case which is awesome for what it offers and it has a little fan under it, I do however dislike that all the tuning is on the underside but it had to go somewhere I just prefer it to be on top or on the sides
I updated the original post to simplify it a bit and re-frame it with the new Scosche floating ground adapter. This adapter *is* different, as it...
  • Locked
I got a Gladen RC-90C2 thats pretty small 90x2 @ 4 ohms i'll be removing from my rig in a few days if interested.
So I am planning to build a system in my Ford Excursion and can’t decide on whether I want to use an iPad mini with a sound processor behind it or...
186
97maxima
Loud Trunk?
97maxima
Sc
Cornbreadxd
audiobaun
    May 19, 2024
    May 19, 2024
