Ap1500d - Has anyone had Success?
  • 6
If it does not have a master/ slave switch on either amp. It can NOT be strapped. You can buy a max link and strap them that way. But I would contact maxxsonics before buying it to see if anyone has used the max link to strap that amp. Im sure you can use it, And If you do buy it. The directions will walk you through everything on how to hook it up.
If you're going to run two AP1500Ds then why not just buy one AP30001D? It is basically two AP1500Ds internally strapped in one case, 1500 watts RMS x 2 into 1 ohms stereo or 3000 watts RMS x 1 into 2 ohms mono. I have one and it does rated and pounds the hell outta my subs.
Just trying to save $37
Jackie says other wise...
Good Morning Anthony,
Yes you can strap two AP-1500.1D’s together.
Thank you,
Jackie Alvarez
P. 1-877-AUDIOPIPE
So your boy from audiopipe says you can. Do you happen to ask him how to then lol.
All I know from all the amps I came into contact with. If it does not have a Master/ Slave switch on the amp itself. It can not be strapped.
i actually did. pg 15 in their manual shows you how
Don't see what's wrong with trying to save money lol. I'd rather have them in 2 separate cases so it's easier to install, but that's my opinion.
I also think it would be easier for me to install two amps in my installation rather than the one bulky amp (ap30001d).
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
I use these and they work great. I splice them right before the LOC. One leg on the negative the other on the positive.
My 1964 fender vibroverb. It’s a tube amp for guitar. It has broken many times. But it is a serviceable amp. I can fix it.
73
14K
Tone415
A.K.A FrisnoG
Tone415
San Francisco, CA
Tone415
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
