APMI-2000 running @ .5ohm? Anyone tried it
JLJunkieMX107
Has any tried running an APMI-2000 with a .5ohm load? Like a dummy, I bought 2 used D2 subs, only options are 2ohm or .5ohm. I am hoping that with box rise, it will probably come in closer to 1ohm (exactly where I need to be). I know bigblank did some testing on this amp, did you happen to see how it did @ .5?
Supplying power won't be an issue. I've got a 300A alt, big 3, and 1000a AGM.
Good luck
Holy *****, 370A drawn on the .5ohm load, that's a lot of current. Screw it, this amp is only $170. I'll run it at .5ohm and see what happens.
i wouldn't but wtf.. set gain low man., what would 2k at .5 ohm be?, 22.3volts maybe idk
It is going to come down to impedance rise. I know someone who ran a AP amp at .5 for about a year with no problems. Then he decided to change boxes. Amp died two days later.
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I only have experience with ct sounds. I have the ct80.4 and the ct1500.1 in my sons camaro he is playing them everyday I had the 80.4AB go bad...
The last piece and the system is a wrap, RUX-H02 remote volume/sub knob because we are old and buttons **** IMG_0647 by Jon Polo, on Flickr...
JLJunkieMX107
JLJunkieMX107
Grand Rapids, MI
dragon.breath
    May 18, 2024
    May 18, 2024
