Audio Control D-5.1300 (Can I use with passive crossover component speakers)
  • 2
Yes but why would you when you have the dsp inside the amp?
That is the question I suppose. I already installed the speakers and have one wire running to each passive crossover. I want to use the full range for this amp. I plan on using front 6.5 with tweeter (hertz) and rear 6.5 with tweeter (hertz) and one sub. What’s the best way to do that?
Run it all active trust me better to find the range on your own. It's better that way because you just mimic the range of each pair
Since I have essentially 8 separate speakers (minus the sub) -2 low mids/tweeters and the same in back: I am assuming in need a speaker wire for each. Would that mean I need another amp?
Technically yes but I would ru the 2 sixes and the 2 tweeters off the amp as well as the sub I have a ton of audiocontrol gear 2 dm 810 lc 6 and a lc 7 also a d 4 800. My point is use this gear for how it was intended way too many options use as many as you can.
I agree with AnthonyO. I use a lot of audiocontrol products the dsp is easy to use and with the acr3 you have a few different options on bass knob...
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
This is in a 2015 F150 regular stereo and I'm using the front speakers for a signal. The EQX is hooked up speaker level. I put a cheezy line...
4
emaildougb
CarAudio.com Newbie
emaildougb
Vancouver WA
KicktheSDbasshead
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
