Bad output channel?
  • 2
79z/28
CarAudio.com Newbie
I have a older 4 ch US Acoustics amp that I bought used & has wired to some jbl got 6x9’s.  It sounded pretty good for a while then one speaker got very scratchy sounding, it felt like the voice coil was dragging inside the magnet, I figured the speaker was bad, replaced with punch 4 way 6x9’s and after about 5 minutes of playing the same channel did the same thing!  I swapped input rca and problem stayed with the speaker so do I have a bad output channel?  Could I bridge the 3/4 and nod not mess up other speakers?
sounds like a bad output channel if youre able to replicate it like you are. There are plenty of amps available for cheap that will solve your problem. Do you have a budget in mind? I got a very nice Audio Art 2 channel for $45 from a pawn shop recently and its a sq monster
My 2 - 15" wedge box is around 5 cubes net with 80 square inches of port. My 4 - 8" wedge box is 3.69 cubes net with 43¾" square inches of port.
7
420
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
9
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
79z/28
CarAudio.com Newbie
79z/28
youdoofus
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
